Performing Wldcore Dll Is Missing Fix
WLDCore.dll was not found when the nursing assistant tries to perform an action using Windows Live Mail or other Windows Live programs, for example by clicking an email link on a web page or on the slot of an email. Will someone helps me in performing wldcore dll is missing fix?
Answered By 0 points N/A #320952
Open a person, type “C: \ Program Files (x86) \ Windows Live \ Shared” and press Enter. In this folder, you will recognize DLL files named wldcore.dll and wldlog.dll. Hold down the Ctrl key and select wldcore.dll and wldlog.dll, respectively. Right-click on one of these files and select Copy. Return to the “C: \ Program Files (x86) \ Windows Live \” parent folder. Paste these files into C: \ Program Files (x86) \ Windows Live \ Messenger. You must grant administrator access as soon as the required operating conditions are met. Repeat step three in the following folders:
C: \ Program Files (x86) \ Windows Live \ Contacts
C: \ Program Files (x86) \ Windows Live \ Mail
Try to sign in to the Windows Live Messenger service or try to damage any Windows Live product.
