Periodic and non periodic signal in data communications
Both analog and digital signal can be periodic or non periodic.
A periodic signal completes a pattern within a measurable time frame, called a period, and repeats that pattern over following identical period.
The completion of one full pattern called a cycle.
A non periodic signal changes without exhibiting a pattern or cycle that repeats over time.
In data communication mostly use periodic analog signal and non periodic digital signal.
Thank You.
John Major.
Periodic and Non Periodic Signals are types of Analog Signals that can also be positive or negative. In data communications, a periodic signal is a type of signal that reiterates itself after a definite gap time. While the non periodic or often called as aperiodic signal is a type of signal that does not reiterates itself.
Notifications
