Personal reviews from people who use Sony Sound Forge
I would like to get personal reviews from people who use Sony Sound Forge. I am planning to buy the premium version of it to create and edit digital audio files with high quality output. Please do the needful. If anyone has better suggestion than that of Sony Sound Forge, Waiting for your guidance.
Answered By 80 points N/A #153115
Greetings Coco Youmans,
I've been doing some audio editing in past and I've been using Sound Forge. I won't lie I haven't been using it to an extent you probably will but I was satisfied. Later on i found Audacity which is a free software that finished the job for me. Sound Forge is a more advanced software for sure but I wouldn't be really satisfied with that product considering its price. Maybe before you buy Sound Forge you can try Audicity.
I've been doing a little browsing and judging by the reviews the favor goes to Wavepad. It seems to have more functions then Sony's Sound Forge. Check the website
Hope I helped you a bit.
