Personal server more than 500GB
Hello. I'm in great need of a personal server of more than 500GB. It should be super fast as well. I'm looking for a place to buy one. Please help me on this. Thanks in advance. |
Hello Mandy,
I have read your concern regarding personal server of 500GB. As you’ve said, you were looking for a place where you can buy it, but since you never stated where you are located, I am gonna give you some online shopping available with 500GB.
Here are the following websites where you can find 500GB for personal server. Some are cheap but of good quality and some were expensive to give you the most of it.
Select any of these links to check-out the product and buy online. Terms and conditions depends on the seller and buyer agreement.
https://www.newegg.com/Server-Workstation-Systems/SubCategory/ID-386
https://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/ps3200_users_guide.pdf
http://www.webhostingtalk.com/showthread.php?t=1101631
https://www.seagate.com/in/en/support/external-hard-drives/network-storage/mirra/
https://www.amazon.com/ref=nb_sb_noss_null
I hope I am in the right track of understanding your concern and give you a hand to fix the problem. I hope this information is of good help.
Good Luck!
Mali
