Hello everyone,
My Ainol Media Player has a 4.3" screen size but the battery works incorrectly since I left the player running for extended hours. Now, I am looking for any device that will work best for watching videos only. Teclast and Ainol is no longer making such products so I am looking for a good alternative.
The player should be 4.3" to 5". I don't like bigger tabs as it is not very handy. Bigger screen mobile phone will do as long as it can be use as a video player. I am presently using an iPhone 4S for watching videos but I am not comfortable with the screen size, though it was fine. I am willing to spend dimes on buying new or second hand unit. Anyone have an idea?
Personal Video player 4.3″ to 5″ screen size, what are the options?
Hi!
Here is the two best personal video player that fit you:
1. Viewsonic Moviebook VPD400 = It has 4.3-inch screen. It's screen is HD Digital, thus you will have a great experience when watching through it. It is definitely a portable player. It has quite low internal memory storage with 8GB, but you can insert external Micro SD card to increase storage.The battery can holds up to 6 hours when it comes to video and up to 8 hours when it comes to audio.
2. Coby MP957-4G = It has 5-inch screen thus provides you with better pictures. It has 1080p quality screen, so it is completely HD. It also can operates as alarm clock, calendar, FM tuner, gaming apps and many more. It can connects with HDMI. That means you can surf internet to download videos, movies and many more. Unfortunately, it only has 4 GB internal memory storage.
