Philips Ambilight with APP to control lighting effects?
Can anyone explain about this
What are all needed with cost and detailed info on how to connect them and get it to work?
Hi Henderson,
The Philips Ambilight App provides following features:
1) It has ambilight 2-sided view which intensifies the experience
2) It provides 3D experience with 3D glasses
3) It has HD plus pixels for advanced details and clarity of the image
4) It has a frequency of 300 Hz for perfect motion
The cost of Philips Ambilight is 2800 Pounds
The steps to connect the device to your laptop or computer is as follows:
1) Switch the laptop/computer Off
2) Connect the laptop with the device using HDMI cable
3) Switch the device ON
4) Press the 'Source' button, select the type of connection you want
5) Switch the laptop/computer ON
6) Press the 'F 8' key to toggle between the device and the laptop/computer for the specific features
7) Remove the HDMI cable when the process is completed, restart the system
