Philips TV en flash problem !
Hi Guys, I have to ask when I use my philips internet tv, I'm unable to see flash videos. Is there any problem with my philips tv en flash ?
Hello Petrusic,
 I'm very sad to inform you but Phillips Smart TV does not support native Flash videos as of now. But the good is news is that they are developing a firmware update which will enable TV users to watch Flash videos.
As for now, the browser in the TV only supports CE-HTML format which means you cannot watch videos because all of them are Flash powered. It is not possible to install Flash Player neither. Your best hope is to wait for firmware update from Phillips.
Best wishes to you.
HI,
Check the current TV software version.
Before updating the TV software, check the current software of your TV. Latest update software version found on www.philips.com/ support, it necessary to update the TV software.
1. Press on the TV remote control.
2. Select [Setup]>software settings>Current software info, then press OK. All new version are displayed the monitor.
Mohsinaece
