My phone had started lagging a lot recently. I restarted it and deleted all unnecessary apps, but it’s not getting better. Is it because if the new OS update? Because this problem has never occurred before, and has very newly become a major problem since I updated my phone.
Phone Lags After Installing Android Oreo
Mobile phones begin slowing down as their internal storage is filled up. You should delete all unused apps and pictures, or move them to an external storage device. Also, close apps that you are not using, delete app cache and try to stop using live wallpapers frequently.
Cached data can be deleted in the following way:
Settings > Apps, choose an app, and Clear Cache option. There are programs available on the Google play store that can also be used to automate the process of clearing cache.
Cached data must frequently be deleted for the smooth performance of your device.
