Hi techyv,
I want to edit some free gig ticket template. I downloaded some free template from the internet and make it as a basis or reference on creating my own ticket logo. This is for my friend’s activity, can you suggest on the software that is easy to use and can edit pictures?
Hoping for your help. Thanks.
Photo Editing Software for Modifying Ticket Template
Hi Kristen!
What is the file format of the template that you have downloaded?
If the file formats are any of the following: BMP, JPEG, PNG, Portable Bit Map, and TIFF, then I suggest that you use Adobe Photoshop, Picasa, Autodesk SketchBook Pro, Aperture, or Artweaver. Picasa and Artweaver are free software while Adobe Photoshop, Autodesk SketchBook Pro, and Aperture are commercial software which means you have to buy them.
If you downloaded a template in PSD format, then you can only use Adobe Photoshop to open and edit it.
