PhotoPlus X3 Doesn’t run in Normal user
Hello, I am new on this forum and need your help. I am concerned about other users who have posted same threads with quite similar problem and I went through them with great care. After reading those threads, I got a new kind of problem which is stated below
Same like other users, my PhotoPlus X3 was not running after a bad computer shutdown and Windows disc repair. My operating system is Windows Vista. After attempting the un-installation and re-installation PhotoPlus, I got the same problem.
Then I changed the date of Windows to a date before that bad shutdown, but also I am failed. Every time I am getting this error message 'Abnormal Program Termination'.
According to one of the other threads where they mentioned that editing the registry and re-installing the software could be a solution. I went for it and used my Admin user to use the solution technique.
I tried to load PhotoPlus before that and somehow it worked!! After that I moved back to my normal user and again received the same message 'Abnormal Program Termination'.
In my PC there is a user I always keep for visitors if they like to use my computer and PhotoPlus was also working on that user mode. But I am unable to get it run on my normal user.
So it is obvious that the PhotoPlus software is running perfectly on my machine, but not working for only one user. What could be the reason behind it? Can anyone suggest me something and what could be the procedure to get it running on my normal user mode?
