Hi Experts,
My current operating system is windows 7 and I am using photoshop cs3 version, there are lots of design tool for drawing screens how can I download it in my photoshop cs3 is there a way to merge it to the files of photoshop? Or give me another software that generates more features about design tools for drawing screens.
In Photoshop about design tool for drawing screens
Hi
Actually photoshop is not the best graphic design software in the world. And also you are using photoshop cs3. But now photoshop cs6 is available. It has more design tool than cs3. And also there are many other better softwares for graphic design. Some of them are listed below. You can try one of them.
Adobe creative suit
CorelDrow graphics suit
Xara Designer pro
Hi Mikee Langford,
Photoshop is powerful software on editing, retouching, illustrating photo. But, Photoshop is raster base graphic software, so it is not the best choice for drawing.
I recommend you to use other vector base graphic software such as Adobe Illustrator or Corel Draw for drawing.
After you design by a vector base graphic soft, you can open it or import to Photoshop to add some more effect.
Hope this helps
