mario yulia
Posted on - 06/05/2012
Photoshop is creating a problem today. Tga, bmp or exr file format doesn’t open all of a sudden.
I get the error message: “Could not complete request because of program error.
These formats are suddenly missing in the open dialog box.
Please, give me a suggestion.
Dear Mario Yulia,
Seems you have some sort of Photoshop problem which is related to extension format, i don't know about which version of Photoshop you are using, Its important to know. By the way you are facing a such problem cause of some missing .dll files into your Photoshop directory. You need to reinstall Photoshop Application. Here is the steps to reinstall it ….
Step One : Go to Start Menu and click Control Panel
Step Two : Click Programs Tab
Step Two : Click Programs and Features
Step Three : You may see a list of Installed Application, select Photoshop from that list and double click on it. A window will appear, select Repair and have a go.
Step Four : Restart Your Computer.
I hope this will help you to solve your problem.
