Kurt Baclig
Posted on - 05/06/2013
Hi All,
I'm installing Photoshop DAZ studio bridge 64 bit in my Windows XP 64 bit pc when the installation just quit on its own. There was no error generated. What could be the problem? Please help me.
Thanks,
Kurt B.
Photoshop DAZ studio bridge 64 bit installation
Hi! Regarding to your problem, did you try to launch the application after the automatic quit of the installation. If not better to try it, if the software is not working it means that the software is not installed properly I recommend you to install it again.
If the second installation encounter the same problem, check application package and make sure that you downloaded this software completely. I suggest to download another one and try to install it to your computer if the same problem encounter again, I think this software that you downloaded if not compatible with your Operating System
Hello Kurt,
Try to launch the application after the installation is automatically closed. If it does not work, then install the program again. If the same problem persist, check the application package and make sure that the software was downloaded completely. In case the problem occurs again, then know that the software is not compatible with your Operating System.
