Photoshop documents – cannot be saved by Mac Pro
an error in saving the Photoshop document”, the current file reference is then erased by the dell server and I have to work on it again. I worked around the problem by saving the documents locally and then uploading them, but it takes time. I hope someone can provide a solution. Thank you.
