Photoshop doesnt turn on !
I have installed two software's Photoshop element 10 and premier 10.
But whenever I try to turn on Photoshop it gives an error message 213:11 and asks to restart ! What should I do ?
On using Adobe Photoshop when suddenly you see this message then in my view,
This incidence occurs when the SLStore Folder is set to read-only.
To be of the same mind it, disappear the read-only retard from the SLStore folder “Windows” or make it to read/write taking over.
Now you have to do some repairing in your Windows XP.
A) Go to C:Documents and SettingsAll UsersApplication DataAdobe.
B) Now go to SLStore folder, right click on it and select Properties.
C) Here you will find a check-box, deselect it by clicking left moue key.
D) Now launch the Application and again and see what is the result.
I am sure you will get your desired result.
Hi garry ,
I too had these errors before, I guess you are having trouble with adobe premier ,
There are many suggestions : –
1. Try to update your Photoshop or adobe premier to the latest .
I am using adobe Photoshop CS5 and i am very comfortable with that creative suite.These updations will cause the upcoming less bugs and adds more features.
2. Make sure you are an administrator , if you are running on admin account then right click the adobe product and then select run as administrator.
3. Download Adobe support Advisor to run an analystation of your adobe product and its installation
Hope that solves your case .
This error occurs when the SL store folder is set to read-only.
To resolve it,remove the read-only check from the SL store folder (Windows) or give it read/write access (Mac OS)
Thank you Amoyo Augustin and Lesten Pasio.
I follows Amoyo's instructions on editing the SL Store folder.
I also updated my Photoshop.
And sure enough, after the reboot, the error message is gone and the Photoshop works fine.
Many thanks TechyV!
