Can you help me? I never have any problems running Photoshop Elements 9 on my Windows 7 in the past. But lately, when using the text tool in a new text box, there is nothing on it. The inserted text can be seen in the layer name, but on the actual side, the words are not appearing. There is no problem in customizing its font size or style, and the layer on top of it. I tried the CTRL+ALT+SHIFT to reset the tool setting to no avail. What should I do? I need help please.
Photoshop Elements 9 Error in Text Tool
A pleasant day to you. I encountered that kind of error before and all I did is I open the image and texture, drag the text on the image, I selected the "horizontal type mask tool" , made a box where I will put the text and just type in the text inside the box. You can click the "move tool" (from top left corner) ,press "select >inverse" and then press "delete" on your keyboard. After that, just go back to "select" and click "deselect" and you're done. It works fine with me. You can try it to and I'll be happy if you let me know if this solution also works for you. Thanks and have a nice day.
-Zorian
