My PC frequently crashes when I am running a particular program and “Adobe after-effects Error 45::36” is displayed as the error message. Apart from that, my computer intermittently freezes for a couple of seconds and Windows happens to run sluggishly and respond slowly to peripherals whenever i meet with this particular error.
Photoshop file format error: the “After effects error 45::36”
There could be several probable causes behind the exhibition of such error, such as Corrupt download of Adobe, incomplete registration, adulterated software uploads, viruses, malware infection on the OS, mistaken deletion of important supported files, or erroneous troubleshoot of run-time execution.
But there is nothing to worry. You can follow certain simple steps to overcome this kind of error. You can use a trusted registry cleaner to scan and fix registry problems related to Error 45::36. This will help you resolve missing file references, invalid entries in the registry, and all broken links in it. Make sure you have backed up your data before the scan to prevent damage or loss of data.
After a full malware scan, followed by a system Junk and disk clean-up, you can try updating the Device Drivers in the PC. Go to Windows System Restore and “Undo” all recent changes in the System. Reinstall the “Adobe After-effects” program by uninstalling via “Programming and Features”. This is the one that associates with your error.
Once done, you can see that the error no longer exists, using the “Windows System File Checker”.
