Photoshop Saving Read Only Files
Just awhile ago, My Photoshop CS3 has been saving files as read-only. Every file that I save is in this format. I can’t find the option to remove this feature. Where can I find it?
There are 2 possible cause of this situation its either you save the file in the wrong way or you didn’t remove the read-only attributing from the file. To remove the read-only attribute just right click on the file then properties, check off the read-only attributes and then click apply.Â
Good day, I think the problem is where do you save those files you create in Photoshop. Try saving the files in a new or in the other folder. I personally recommend to create a new folder and then right click the icon . Go to properties and then see if it is in a read-only mode. Unchecked the box of read-only mode if it is on , if not leave it as is. Then try saving your PSD file in that folder and check if still the same as before. You can always turn on or off the read-only mode by doing that procedure. Sometimes a read-only file is useful to prevent unnecessary editing .Â
Good day Susan,
