I recently purchased the all-in-one Photosmart printer and its model no is HP c7250 scan to computer. Yes, this is my question as to how as I should setup my scanner for the first time I will be using it?
Photosmart All-in-one Printer HP C7250 Scan To Computer
Hello, it is good that you are going by the traditional methods to start using your printer, and want to know the proper way. Since you mentioned you are using it for the first time, I will mention the steps as to how you are supposed to do it the right way for a Windows OS. Follow my steps:
From the official website of HP you must download an appropriate driver for your printer by entering its model number. Follow the guide to connect the printer and the installation should include HP Scan.
Install the HP Scan software.
Place the document or the photo that you wish to scan with the print side down on the scanner glass. Close the lid after doing so. If your printer has the ADF feature, you can insert multiple pages to scan them. You must not insert photographs in the ADF (Automatic Document Feeder).
There will either be a Scan button on your printer or a Scan menu which you must enter to choose the Scan job type. When the scan completes, a folder will automatically open containing the scanned document.
If your printer does not have a Scan button or menu, follow the steps below:
Search Windows for HP, and choose the printer that is connected.
Select “Scan a document or Photo” so that HP scan opens.
Choose one of the options and you can also change their properties in the right section of the window.
If you purchased a new printer, you won’t be able to use it until you install the software or the driver. The software usually comes with the package when you buy it or you can download it from the manufacturer’s website. To make sure you have the latest software, download it from the website.
HP Photosmart C7250 All-in-One Printer
On your computer, open your web browser then go to HP Photosmart C7250 All-in-One Printer. Download and install all available drivers and software for your printer. Before downloading, check that your correct operating system is selected. If you see a different operating system displayed on the page, click “Change” then select your correct operating system.
When installing the driver or the software, make sure the printer is connected to your computer via the USB cable. Basically, you don’t need to do anything or any configuring after the installation. You only need to configure it when you need to print a document. You can also perform a test print with the printer by following the instructions on the manual.
You need to perform a test print after the installation so you will know if the printer prints properly. If there’s a problem with the print, you need to recalibrate the printer by following the instructions in the manual.
1....
