PHP CMS templates with control panel
Hi all, I would like to have a PHP CMS templates with control panel that will have the ability to manage website information, Will any one help me by providing the same or is there any online provided, which will have free such templates, Please do the needful. Thanks, Anna W Brown
Answered By 0 points N/A #198358
Hi Anna W Brown,
I have here one CMS template that is run by PHP programming, It comes from vectorial PIXEL, credits for them, you can access the file over here.
This admin panel is intended for programmers that uses SQL databases and want to access database using PHP programming, at first, I thought that I can recommend you to use XAMPP for that PHP program but then I thought that you may want to implement the PHP program globally, this is the best thing that I can recommend for you.
I have provided screenshot for better view.
