Corey
Posted on - 08/27/2011
I am using PHP CMS i.e WordPress. I install it in my localhost. When I check the site, it shows an error message : [an error occurred while processing directive]. I capture the screen shot and put in this post. Help me if anybody knows.
[an error occurred while processing this directive] The requested URL was not found on this server. If you entered the URL manually please check your spelling and try again. [ an error occurred while processing this directive]
PHP Error : [an error occurred while processing directive]
Hi Corey,
First of all if you going to put the error message please post the exact message. I looked nearly in your screen shot so I can see what the problem was are. Here is what I found. You typed a wrong coding or address of your URL that is why you have this kind of error. So I suggest that before you run it again please be sure that your URL was right and correct. In this action you will run your program without any problem occurred. So recheck your correct address then review it. after that put it back and I assure you that your program is going fine. This would help.
mughal
5 points
You can see the real error when you run the CGI script directly,
http://www.ufoinfo.com/search.shtml
“Internal Server Error
The server encountered an internal error or mis-configuration and was unable to complete your request.”
Which is the same error as last time.
My advice is also the same as last time.
Which was,
“There are many reasons why this might happen. The most common is a corrupted set of index files. This often happens if you have failed to upload some files, or have uploaded the files in ASCII ftp mode instead of binary FTP mode (when using an external FTP program).”
In addition see this FAQ for another common problems and solutions to getting the CGI script to run.
