PHP my SQL server connection error
Hi TechyV buddies!
I am having some problem with my DW. I am a bit new using DW so I am on the point of knowing things yet. I was doing a work on DW. I was trying to make a dynamic data tables for our login page when suddenly an error pops out when DW tries to connect to the server. A mapping error appeared but the root file is correct. I have tried to configure it by connecting DW to MYSQL admin but nothing happened. I have also checked DW if it is really connected to the server but it is indeed connected but it cannot connect to the root folder. I should have attached a screen shot here for you to see the problem but I don’t know that either. I don’t know what could have caused this problem. Can anyone help me solve this issue? I really need a help here guys. I would be delighted if any help is presented. Thank you!
