PHP versions 5.5 and later do not support windows XP
I have installed on my PC PHP5.5 and when I tried to run the program this error appeared on my desktop. On the website it said that is compatible with Windows XP SP3 and 2003 but it seems like is not. I think it should work but the problem is with my Windows XP. Can anyone help to solve this error please ? Why is not compatible with my Windows even on the website it says it is ?
Thanks !
There has been an error.
PHP versions 5.5 and later do not support windows XP or windows 2003.You will need to install a different version of BitNami Ghost Stack that includes version 5.4 or earlier.
