The PhraseExpress Portable 8.0.151 Software
The PhraseExpress Portable 8.0.151 is the best typing software. Is there any way to change the font size?
This is a text expander program that recognizes the texts you are typing and will automatically offer a list of choices to complete the texts you are entering.
This application adds a boost in your typing productivity because it works with every other Windows applications. The application works in the background and monitors everything that you type and correcting any errors that appears as you type.
For example, typing the word “teh” will automatically be corrected to “the” or let’s say you forgot to include a space between two (2) words like “butbefore”, will be corrected to “but before”.
It includes system-wide spelling correction that has more than 10,000 spelling corrections in seven (7) languages.
To download the portable version of this application, PhraseExpress Portable 8.0.151, you may visit and download it from DownloadCrew — PhraseExpress Portable 8.0.151.
This version supports Windows XP, Windows Vista [32-bit and 64-bit], and Windows 7 [32-bit and 64-bit]. To download the full version, you may visit PhraseExpress — Text Expander for Windows.
Notifications
