Hi there. I'm trying to play Physx puzzle games like Cubophobia on my desktop but it seems to be choppy. My desktop has an Intel Core i7 processor, 4 GB RAM, 1 GB Nvidia GeForce Video Card and Windows 7 64 bit. Do I need to set it to a lower resolution to have a smooth gameplay?
Physx puzzle games are choppy on my desktop
Hi Edward,
The specifications on your computer is impressive, some would suggest upgrading or changing CPU however since you are already using i7 then we will remove that on the list. Now what I can suggest is maybe you can try to look into gtx650 this already has physx there where even comparisons with NVIDIA and there are great difference with the result.
You can check this guide to see the graphics card hierarchy so you can match what you have on the computer.
