I installed AGEIA PhysX Hardware with 2.4.9 driver but it shows me the following error message which I can’t fix it easily. I extremely need your assistance to resolve this error. Any help would be greatly appreciated. Thanks in advance.
Serious Warning
PhysXHardware not detected! CellFactor requires Agela PhysX Hardware, with ‘2.4.9’ runtime & drivers installed.
PhysXHardware with 2.4.9 driver is not detected
Resolution 1:
If you suspect that you mistakenly deleted a physxloader.dll file, you will need to go to the recycle bin and recover it. If you have emptied the recycle bin, look for a free file recovery program and use it to recover the physxloader.dll.
Resolution 2:
The physxloader.dll could be related to a virus or other malware infection on your computer. You will therefore need to run a virus or malware can on your entire system.
Tyler
