Picasa psd thumbnail viewers not working in an upgrade to Windows 7
I upgraded from windows xp to windows 7 recently ( I have an Acer Aspire). I have reinstalled all the programs correctly and almost all of them are working correctly. The major problem that I have is that Picasa psd thumbnail viewers are not working at all. I have got the latest working of Picasa.
Best Answer by Sandra R Butters
Answered By 10 points N/A #149639
Hallo Hunter,
That is an error due to compatibility issues, and therefore you will need to do the following:
  • First of all check the system specifications of the windows 7 you upgraded to.
  • Check to verify if the system is a 32 bit or 64 bit.
  • After that go to the internet and download the Picasa psd thumbnail viewers that are compatible and then install them.
Carl
Answered By 30 points N/A #149640
Hello Chasee,
The problem you have mention it sometimes occur after upgrading the windows. You can run a Picasa latest version on windows 7 there is no doubt about that. Now the problem you are facing it might be happen if any settings changed while upgrading the windows or the latest version of Picasa that you’ve downloaded is not perfectly done. So recheck on those settings and you can also use Picasa psd thumbnail viewer to resolve it. For that you have to download this software from the internet. Hope this will help.
Good luck.
