Picasa Web- An error has occurred
Hi, posting here guys the problem I encountered while using Picasa, I received an error message about a program error, and the application needs to be closed, there a lot of choices in the error message, that is why I pasted below the screen shot of the error.
Picasa Web- An error has occurred. Look for technical support in the forums (www) further advices and updates you can find also in the internet.
This is my first time to see this type of error message, that is why I have a hard time figuring out for some solution to the problem, and the error message is not elaborating will the cause of the problem, please share you ideas on my problem, I hope to hear from you guys soon, thanks.
Answered By 0 points N/A #98321
Hi there,
This is actually a problem of your PICASA installer. As what I have seen in your forum above, the Picasa is CORRUPT. One way to solve this is to DOWNLOAD another installer of the PICASA. This is a PICASA 3 Version and this is what I used.
You can DOWNLOAD the latest version, Picasa 3.9, from Picasa | Download Picasa. This version supports Windows XP, Windows Vista, and Windows 7. TRY to download it and RUN until FINISH.
If you have your DOWNLOADER, you can install it manually to avoid your problem. I hope this helps.
The Solution is EASY at TechyV….
