kurtis1318
Posted on - 09/25/2011
Hi!
I am experiencing an issue with my Google Chrome. As I open the initial page of Facebook, for example, the page is okay but as I open pages to new tabs, some pictures do not load properly. This applies to other websites as well.
I wonder if Java needs to be updated or do I need to reinstall Google Chrome? As I checked Google Chrome's Properties, it shows that I have the latest version(14.0.835.186 m).
Thank you!
Pictures on the web pages do not display correctly on Google Chrome
I think you should do what you are thinking. Reinstall the program first and then try browsing again. Also update all of the needed programs for the web browsers eg. (Java, Silverlight, etc.) and see if there are changes in the performance of your Google Chrome.
Try also using other web browsers to see its experiencing the same problem, preferably (Mozilla Firefox, Internet Explorer, Safari). After installing these programs, make sure to restart your system to save the settings properly, then try to open the web browser then start testing it.
I hope this solution helps you with your problem.
Hi kurtis1318,
Have tried to use other browser like mozilla,opera?. When it is the same I think you just have a low internet connection or the server of the site you are browsing that time was having a problem.
If it is okay to other browser I will suggest that reinstall the program, Since you have the latest version of that program.
Hope it helps 🙂
