Thanks in advance for the help. I made a pie chart nut it displays an erroneous total % which I cannot remove. When I right click and opt to never show it, it is still there. When opt for always then select never again it disappears, but then reappears after I view another tab then come back again.
Please help me to fix this issue.
Pie chart nut displays an erroneous total % which I cannot remove
Hello Martin,
That could be because you have set the pie chart to use percentages, and therefore you will need to change that to resolve the issue. You can also just try using a text box to insert the value especially if it is a single value that is causing those issues.
Nicke
I am sure you are using the Microsoft excel to draw the pie chart so you need to define limit for the chart first so you can not exceed the limit and then from the chart setting you will be able to delete the amount and to see the chart only.
Also see the when you enter the data in pie chart it does not exceeds the limit for the given chart limit and i am sure that you will be able to solve your problem.
Smith Thompson
