TELNET command is used to login from one system to another system that is to remotely login to a system on the network. Login name and password are required if you are logging in to another account on any other system.
For ping to work with Telnet, Firstly Install the TELNET. Do check that the Firewall is not blocking the Telnet.
Check the Linux system to ensure the Telnet is enabled on it and no intermediate firewall is blocking it.
Create an account on your system with a valid username and password
To check if the Telnet service is running, log on at the Linux console and use this command:
netstat –a | grep “Telnet. *LISTEN*
The output should be this
tcp              0       0       *.telnet                           *. *                       LISTEN                 Â
Ping is one of the most common method used to test connectivity across multiple networks.
Ping sends echo packets that request a corresponding ICMP echo-reply responses from the device at the target address, most servers respond to a ping query.
Three way handshake occur between Linux network and thus how ping work in Linux network
It's good to hear about your concern about Linux system. I have found some links which could surely assist you on how to ping or Telnet on Linux system. This would be the fastest way to assist you, I hope this would be of great help.
In order for you to get ping program to work with Telnet on Linux, you should check the following: First, install Telnet client to your machine and add an exception to the firewall. Specify the name Telnet so that your firewall does not block Telnet. Then, Check UNIX server to see if it is enabled.
Telnet could be disabled to enable the user to you use SSH and create UNIX login Username and password. Now, log on to see if Telnet is running. Use the console command and enter the code provided in TELNET.txt file attached to this message.
RICH Miner officially launches a new mobile cloud mining application, subverting the traditional mining model! No need to buy mining machines, no technical experience required, just a mobile phone, global users can start the...
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
