Hannah B
Posted on - 10/19/2011
Hey, I am using Android 2.2. and I have trouble configuring the PINsafe Client 3.8.
Everything seems to be working fine and I followed all the steps correctly but I’m still getting the failure error message:
Failure
Please check your settings or try again later.
I’m not sure what I could be doing wrong so any explanation is welcome.
Thanks in advance.
PINsafe Client 3.8 configuration error
Hi Hannah B,
A pleasant day to you. You got that failure message because you have entered invalid Mobile provision code many times or the allowed time for provisioning your device has been outreached. I suggest you to download a new set of security strings for your droid to be able to solve your problem. You really need to validate your mobile phone's security strings by carrying out a successful proviison. If you follow all these process, I assure you that you will not get that failure message again.I hope it helps. Have a great day and happy week end to you!
-Zorian
