Gary D Reed
Posted on - 05/29/2013
When I was using the Software Developer Kit (SDK) Pitch Helix command in Inventor 2012 64-bit, I received an unhandled exception error. Please help me to find the solution of this following error.
Unhandled exception has occurred in a component in your
application.If you click Continue, the application will ignore this error
and attempt to continue.
Pitch Helix command in Inventor error
Hello Gary,
That problem usually occurs when Microsoft Data Access Components (MDAC) is missing on the computer. The .NET application needs to have MDAC in order for it to access the data from the database.
So you will need to install MDAC on the computer. You can get it from the following Microsoft Developer Network (MSDN) Web site: https://docs.microsoft.com/en-us/sql/connect/sql-data-developer
Fletcher Hoss
