I am currently facing problem with Direct X. After installing last version, when I wish to play games that uses 3D accelerator, the following error message upper. Though I still not sure, what is the actual cause for the error, but if you know, please tell me the solution.
Pixel Bender Error
A Pixel Bender error occurred:
Melisa
lee hung
75 points
Pixel Bender Error – A Pixel Bender error occurred:
Hi Melisa,
This error occurs sometimes due to having your graphics processing unit working in the dual usage mode. Some monitors can with multiple graphics which sometimes pose problems when used simultaneously. These adapters may cause major problems especially in Photoshop and openGL.
Also, if the graphics adapters are not of the same make and model then that could be a possible cause of the problem, that is, due to compatibility issues with the general specifications of your system. They should also have the capability to support the same versions of openGL and the shader model, or else it will crush and lead to problems as the one you are experiencing.
Hope this helps.
__
Lee Hung.
