Zebbena Laz
20 points
Posted on - 12/14/2012
Hi everyone!
I am planning to create a blog panamahatshop, It is a topic I am very interested and  I had much experience shopping in it. I like to ask where is the best site/place to create a free blog and what to consider in preventing copyright issues when writing it.Â
Thanks!
Planning to create a blog panamahatshop
I can you a best site to create your blog. In this you can select any template. There are more templates and you can decide which is the best suit for your blog. This is absolutely free. But it you want to upgrade to premium you have to pay for that. That’s all. When you write something on your blog don’t copy someone’s contents. I give you a tool which can check copied contents. So you can avoid from it.
Please go to the link which I mentioned below.
https://www.wix.com/
