In my country, I noticed that Fortran, a rare yet high paying programming language is in demand nowadays. I have small Java background and a bit of Python knowledge. I would like to try out Fortran any time soon so what would you suggest I do to help me learn and understand Fortran? Should I use Fortran as my main development tool?
Planning on Fortran Development, Any Advice?
You can use Fortran as your main development tools for yourprogramming. Before doing this you must have to got a clear idea about fortran. I understand that, also you are so interested to learn about fortran. Â
Actually fortran is a programming language with general-purpose, procedural, imperative programming language. It is specially built for numaric and scientific computing perposes. You don’t signified your purposes, that what kind of programming you want to play with. I suggest you to visit this site for a better learning and understanding about fortran. The site is  https://en.wikipedia.org/wiki/Fortran
Also here you will be find out it’s installation process and how to use fortran. https://users.cs.jmu.edu/bernstdh/web/common/help/fortran-setup.php and https://www.absoft.com/products/windows-fortran-compiler-suite/
If you clearified more about your pc and operating system, it would be more perfect and the solution will be more effective. However, hope this all may work.
