Planning for Front End Pool Pairing
Hello fellers,
I was using Lync Server 2013 when I encountered an interesting issue which occurs during testing out a paired pools functionality involving the Topology Builder. This article at TechNet pretty much explains paired pools well: Planning for Front End Pool Pairing.
So, after I selected a backup pool to use as my primary pool, I proceeded to publish the topology, but suddenly I got this error:
Error: Script failed when installing "CentralMgmtStore" on "BETA-LS15-SE1.beta.deitterick.comrtc". For details, see the following log file: "C:UsersAdministrator.BETAAppDataLocalTempCreate-CentralMgmtStore-BETA-LS15-SE1.beta.deitterick.com_rtc-[2012_08_01][12_13_34].log"
![Error: Script failed when installing "CentralMgmtStore" on "BETA-LS15-SE1.beta.deitterick.comrtc". For details, see the following log file: "C:UsersAdministrator.BETAAppDataLocalTempCreate-CentralMgmtStore-BETA-LS15-SE1.beta.deitterick.com_rtc-[2012_08_01][12_13_34].log"](https://www.techyv.com/sites/default/filesx/users/Images/Error-Script-failed-when-installing-CentralMgmtStore-on-BETA-LS15-SE1-beta-deitterick-com-rtc.jpeg)
