Play poker stars the computer has slowed down
Hi, each time my father tries to play poker stars on his computer random windows do pop up. As a result, the computer has slowed down. What is the problem and how can I fix this? I am seeking for a solution that will not cost me because I am broke right now. Who can help me with the solution or idea? I would gladly appreciate.
Best Answer by Geace Jovo
Answered By 5 points N/A #114543
Hi Guru,
Usually, a flash player can cause your PC to slow. Unstable builds of flash player causes this. Try to update your flash to a stable build. If this doesn't fix it. It could be you PC slowing down. Try to download and  activate pop-up blockers for your browser as well.
Hope this helps.
Answered By 10 points N/A #114545
Dear I-Guru
I have read your question and I understand that you need to help your father play his game without having issues with his computer.
1-     Whether your father plays this game online or it is downloaded to the computer, it is very important to run a full system scan and make sure that the computer is free of viruses, then start the computer and try again.
2-     If you are still having windows popping up, then you should consider downloading the game software again, and it is very important to download it from a secure place like the official site of the game
3-      You can uninstall the game safely from clicking on start menu, then control panel, then uninstall programs, you will find a list of all the programs that you downloaded, click on the program you want to delete ( your game ) and uninstall it, once your done click finish and restart your computer.
Download PokerStars again and install it to your computer.
4-     If your computer is still slow after downloading the game then try to check the following:
–      Try not to run any program in the computer while you play that game.
–      Try to delete unnecessary programs from your computer (the same way from start menu and control panel) because may be your game needs more space.
–      Do a disk clean up by clicking on start then control panel then disk cleanup, it will show you how much you can free your hard drives
–      Make sure that your computer is not overheating while you play ( clean the dust from your computer )
–      If your computer is still slow, then it might need more virtual memory, you can download this program for free that gives your computer and games the best performance.
–      https://www2.razerzone.com/cortex/boost?utm_source=iobit&utm_medium=redirect&utm_campaign=iobitgbredirect
Best Of Luck
