Hi, I have some TS files to view. When I was playing it on window media player I got some errors. Can I play those files in windows media player by fixing any plugins or I want to download a Ts file player to play those files?
Play Ts files on WMP or Ts file player
Hi Smithkings,
 Windows Media Player should be able to play .TS files. I think the files that you are trying to play is corrupt, therefore WMP gives you an error message. If it's true, then you can download VLC media player to play .TS files.
 VLC media player is a very popular media player, which supports almost any file format.
I think you will come to love VLC media player You can grab it in here.
 I hope this helps you.
