Hello friends at Techyv,
Can you let me know if playbook has corresponding applications for Flipboard, Skygrid, Yammer, Linkedin, and Hootsuite?
What’s its recommended RSS reader? Anyone who had a chance to play around with it? What do you think of it?
Hans
Playbook and corresponding applications, RSS reader
I will give some of the features that the Playbook application has. When using the BlackBerry PlayBook, you will find that it uses .BAR files, and it will not matter what the application is. The Android files that are used are the ones in the .APK format. You can therefore use the .APK files on a rooted PlayBook only.
When you are using the Android apps on your PlayBook, one of the things that you will need to observe is that you are running the latest PlayBook OS, but you will need to be careful since some of the native applications are broken or missing in some latest versions. Some features that you will need to check if they exist are the end user features such as the video chat, email, calendar contacts, and video store. Some of these feature like the email you will find that it is also in the applications like LinkedIn.
-Thompson Locker
