Player for dat audio file in android
I want to play an audio file on my android phone. What is the best free player for this?
Also can you put a website where to download it?
Thank you.
Thank you.
Hello Anthony,
I would recommended you MortPlayer Music or MixZing Media Player. It’s easy to use and have plenty of features and also have a good interface. MortPlayer Music you can download and install from here or if you choose MixZing Media Player go to this link: On this link you can find out more about their features and choose who will fit at your requirements most.
I hope this will help you!
If you want to play an audio file on your Android phone like MP3, for example, you can install any media player. A media player can play both audio and video files. Try downloading VLC for Android. It can play not only videos and movies but also audio files like MP3 (.mp3) and WAV (.wav). The latest version of VLC media player varies by device.
VLC media player for Android is rated 3+. Another app you should try on your phone is mPlayer. This app is different from the MPlayer for Windows desktop application though they are both media players. Their developers are not related to one another. MPlayer for Windows doesn’t have a version for Android phones. Download mPlayer on the Google Play store.
The latest version at the moment, mPlayer 1.2.2, requires Android 4.0.3 Ice Cream Sandwich and higher. mPlayer is rated 3+. It seems this app has not been updated for a while.
