My PS4 automatically ejects discs outside when am in the middle of a game and can't put it back in like it has a another disk inside it and also it makes a noise when inserting a disc. Does anyone have the same problem? Is there any fix for this?
Playstation 4 ejects the discs automatically
As I have searching about this issue, I found out that many users are experiencing this problem in their console. And most people who experiencing this error are those consoles are sitting horizontally, so to fix this; try to stand it up vertically. If the problem still persist and you still have your warranty, try to return it to your local store where you bought it so that they can return it to Sony and provide you a replacement.
I hope this tip will help you.
Martine Paul
