Please answer this technical questions on aprwin
My operating system is Windows XP and I am currently using ARPWIN Version 5.0. I am using arpwin to verify the yearly percentage rates and reimbursements and to check accuracy. I am happy with APRWIN version 5.0 but they recently released APRWIN version 6.2. Now, my technical questions on aprwin are:
  1. Is it possible to keep both APRWIN version 5.0 and APRWIN version 6.2?
  2. If it is possible to keep version 5.0 whilst version 6.2 is already available, what is the procure to keep my version 5.0?
Answered By 30 points N/A #147243
Whenever a latest version of software is released the older version automatically asks to update the previous version. Whenever you update the previous version or install the new version of the software the older version gets deleted. Same is the case with your APRWIN. You cannot keep both the versions on a same computer.
Try the latest version of the software. If you are satisfied with the version continue with the latest version. If not uninstall the latest version and install your previous version.
Thank you.
