Hello there! I will just ask some MySQL questions as I don’t understand them. I need these in my current project. Here they are:
1. What is the use of InnoDB?
2. How will I display only the last record in the same table with equal preference?
3. What is the correct command of counting the number of records in a table?
Thank you for those who will answer!
Please answer these MySQL questions important on my project.
Hi Trevor,
The use of InnoDB is as follows:
a. Row- level locking
b. Foreign key constraints
c. Performance
d. Concurrency
e. Reliability
f. Data Security
To answer your 2nd question, I am making the assumption that the last record in the table has some attribute as largest. For example: Employee Table having employee number as the primary key and other employee details.
Select * from Employee where employee number = (Select max(employee number) from Employee)
The answer to your 3rd question would be:
Select count(*) from table
