Please elaborate on how to remove registry errors that keep popping up
I am a programmer at the beginner level. At this stage, I need to download and install several programs. However, every time I do this, registry errors keep popping up. How to remove registry errors and keep them from flashing continuously?
Best Answer by
Answered By 0 points N/A #330667
There are numerous causes for registry errors. There can be duplicate keys, fragmented sections, so on and so forth. Unless you are looking for specific solutions, here are some common ways as an answer to your query – how to remove registry errors.
You can try cleaning up the registry using the Registry Editor. Open the Run window from the Start menu and type in the command “regedit”. Hit enter. The Registry Editor opens.
Now look for any applications that have been uninstalled but still show up in the registry, locate duplicate keys left behind by the improper uninstallations, remove unwanted start-up components.
If this does not help, you will have to backup and restore the Registry. After backup, you can repair the registry by the following methods-
Open Settings and go to Update and Security. Click on the Restart Now option from the Advanced Startup panel.
When the computer reboots, you will see a Choose an option window. Here, click on Troubleshoot.
Click on the Automated Repair tab in the Advanced options screen. Choose your account and login to start the automatic repair.
Otherwise, from the Update and Security section, go to the Reset my PC section. Click on Get Started, and further choose Keep my Files.
Hit Finish. This will refresh all your files and probably remove the errors. I hope this helps!
