Please Help In Façade Mac Loading Screen Fix Issue
kiel sanchez 10 points N/APosted on - 02/16/2017
I recently installed the Façade game. But when I was trying to run it on my Mac it fails to load. The game does not progress beyond the loading screen. How can I play this game? Please help in Façade Mac loading screen fix issue.
There are several ways to solve your problem.
1. Make sure your computer meets the game’s system requirement. Check the list of requirement from the game’s official website.
2. The game must have been corrupted. Uninstall the game and download the original version from the official site. Now, install this setup.
3. Uninstall the game. Turn off your device. Remove the cables connected to the Network Interface Controller (NIC) and then plug them back again. Start your device and reinstall the game.
4. Make sure your computer’s video settings are adjusted as per the game’s requirements.
Since you have a Mac, try checking first if it is compatible with your computer or not before downloading and installing it. For Mac, Façade supports OS X 10.3 Panther or higher and requires 2 GHz or faster Intel processor, 512 MB RAM, and 210 MB hard drive space. For Microsoft Windows, it supports Windows Millennium, Windows 2000, and Windows XP.
It doesn’t support Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires 1.6 GHz or faster processor, 256 MB RAM, and 1 GB hard drive space. If you already installed the game on your Mac but it doesn’t load or nothing’s happening when you start it, try installing the other version, Façade 1.1.
This problem also happens in Microsoft Windows because of some operating system function calls when it is first launched. Downloading version 1.1 should fix the problem. Go to InteractiveStory.net – Façade and download Façade 1.1.
1....
