Hello techyv.com!
My business is an animator and illustrator. Most of my works are poster making, ads, and the likes. My problem is that I only have a limited fonts on those texts that I used. I've read about neotech pro bold, but wasn't really sure if it will satisfy my need. Is it worth purchasing? Thanks!
Please help me about my animation with font text business
Hello Kenneth
I observe from your question that you really need various kinds of fonts, but you should consider the existence of free fonts online , which means that there is a lot of substance.
But if you still think that is the one that suits you buy it
Also you can visit free font websites such as 1001 free fonts
Please review the license agreement for each font.
Regards
Bowen Courtemanche
Hi Kenneth,
I can relate to your concern as an illustrator myself. You should try out many new fonts as much as possible to broaden your creativity for your profession. I really suggest that you should check Neotech Pro Bold or any other fonts you are interested in. You can go to www.fontsquirrel.com to check some other cool fonts that you can use for your works.
Neo Tech and Neo Sans are both called for a flexible, innovative typeface that doesn't look unrefined or transient. These extreme contemporary typeface was made of extreme simplicity on its structure with a gently drawn, monoline type, open letter form with a flatten, concentrated curves. Neo Tech is a fair deal since they offer more buying options. But you should also consider other fonts which may be also helpful for your business. You can try the Animography Typefaces. They have various animated typefaces with better pricing and you can even get some for free. You can also create your own fonts by using Fontographer.
