RuthC
Posted on - 08/05/2011
Techyv Dear programmers,
I have a problem about my laptop VGA, here's the story I have Acer 4920g laptop with the specifications, 3 GB RAM, VGA, 1.5 GB (Windows 7), 2.2 GHz processor. The problem is when I reinstall my laptop using windows XP SP 2. I checked in dxdiag, my VGA spec to be reduced. So now live 512 MB.
But I have my VGA driver installed. And everything is running fine. I am initiative for incoming bios, with a view times can be set in the bios, but could not. I tried setting the bios, nothing has changed at all. What should I do? Please help. For info my VGA ATI MOBILITY RADEON HD2400 XT. Please help me.
Please help me about the VGA
It seems that the driver’s .inf files don't know the instrumentation ID's for your mobility record. What I advise you to do is to uninstall the drivers and use our several new, so that they present learning with your mobility cut.
For using ATI Mobility Radeon HD 2400, you need to possess a HD monitor display and Blu-ray ride required to use ATI Mobility Radeon HD 2400. I have also the same problem, a grey screen after the apple boot screen. I have a Toshiba laptop with ATI Radeon Mobility HD 2400. Try to check your monitor as well, or just have new monitor.
RuthC
I think I need to buy new monitor, I have uninstall the driver and still not working.
Johnny Depp thanks a lot.
