Hello techyv.com!
My Operating System is Windows 7 and I have here lots of PDF files that needs to be edited, mostly are text. Now the problem is I don't have any pdf editor, I only have here an adobe reader. Please help me download a free software for pdf editing. Thanks!
Please help me download a software for PDF editing
Hello Mathew,
It seems to me you are searching for a PDF editing software. You will find a wide range of free software in the web for PDF editing and you can choose any of these software. I have got a few links for you
http://www.pdfeditor.com/
The above link is to download nitro PDF editor. You can also try the following links
https://en.softonic.com/s/pdf-editor-free-full-version/windows-7
You can also try the online conversion software but it is not good for editing. So I would suggest you to download and install a PDF editor which meets your purpose.
I hope this helps.
