Please help me find a software for Belkin n150.
Asked By 45 points N/A Posted on -
Hello techyv.com!
I have here a PC and I formatted it few days ago, Now I've lost the installer of my belkin n150 router. I've tried to configure it out without the installer but it seems its not working at all. Please help me find a belkin n150 software through the internet that can be place into a usb and reuse it for my own PC. Thanks.
Best Answer by Sharon D Mickelson
Answered By 80 points N/A #166390
Hello there! , you can download your router's DVD software from the official website for belkin here is the exact link http://www.belkin.com/us/support-article?rnId=2752 . You don't actually need the software, you can also configure your router using the manual that was inside the box or by downloading the manual again from the link above.Hope that helped
Answered By 10 points N/A #166391
If you are just suing the Ethernet port of your router, you should be able to configure it without need for any driver software, but if you are using the USB port to connect. You need to download and install the driver software for the device.
These days are supporting software for devices are available online in the product website. The URL will be printed on the device itself. Or you can go to the product site which in this case is belkin.com and get the software by searching model number.
